SS prop vs same size alum ?
Boscoe99 - you are the man!
I did what you said to do, and it worked. I now have an Apollo SS prop that gives my Yamaha F115C a quick hole shot and top speed @ 6000 rpm of about 35 mph on my Cobia 194 CC with two folks aboard.
We just checked it out today on Lake Lanier (Atlanta) and it's never run so good.
I got lucky when I bought an Apollo prop #993143 from a pawn shop that had been taken off a Mercury. Since I still had my hub kit #203, I was pretty sure I could slip out the incomplete Mercury hub (13 splines) and replace it with my #203 hub (15 splines). I did and it fit the Yamaha perfectly. And the prop was in good condition.
So again, you and others on this Forum have helped someone (me) immensely. Thank you, thank you, thank you.
Originally posted by boscoe99
View Post
