Got the unit on the bench for some motor work. Now would be the time to address it. Any clue as to the origin of the occasional squeal ?
squealing t/t unit
4 wire trim tilt
So 2 wires are ground..white and black....blue and green are the power. But am I correct in assuming that if either the blue or green is powered up then the other power colored wire goes to ground ? So now 3 grounds out of 4 wires ?
I had a dry squeal as you described. I put a very light coating on the outside of the rams which stopped it. That was probably 3 years ago. No leaks, works fine, nice and quiet
Note, RB, later posted NOT to grease as I did. As Jason posted, just a touch on the ends normally fixes the squeal.
If neither fixes it, you may want to grease the main shaft the unit slightly rotates on (on the bottom)..
T&T is usually TWO WIRES only. One way to pos and neg will raise, reverse the wires, it should lower...Scott
Originally posted by 99yam40 View PostI would think that a 4 wire T&T motor would have 2 hots and 2 grounds.
one path each for up and down
maybe the pivot point on the motor is what is making the noise as it moves
My $'s on the ram's being dry...
If you just want to move the rams to check, you could loosen the manual release screw(might be too hard pushing down by hand)Last edited by TownsendsFJR1300; 03-27-2017, 08:02 PM.Scott
Dry ram sound is snap snap snap... my engine has not even got to the rams yet. Sounds like the pump is singing the sad song of death
2 hots 2 grounds. But, 1 of the hots has to be grounded to get the other hot to work. Think my issue is the relay, so ordered another, but would like to bench test this unit so I can get it installed. Relay won't be here fore a couple of days.Last edited by scofflaw; 03-27-2017, 08:14 PM.
find a service manual, or maybe someone can post a little out of one if they have one for a 4 wire motor
I do not understand why you say one of the hots needs to be grounded.
on a 2 wire you would have to revers the 2 wires, but with a 4 wire ther would not be that need in my opinion. But I never played with a 4 wire
Squealing or popping sound? I had the popping but after it was bled correctly and full of fluid it stopped. Guess it was air bubbles. I would hose the rams with silicone spray to see if it stops the squeal. Silicone is not going to attract sand and dust like grease. Seals may be dry. Who knows? Use it. It's old....
