Speedi Sleeve Removal
  • Speedi Sleeve Removal
    I need to remove a previously installed Speedi Sleeve. The manufacturer says heat or cold chisel. I tried heat, but there's really not much thickness available to pry against, so no luck there. I'm a little reluctant to take a cold chisel to the crank shaft - any suggestions?
    on 1/17 on this thread:
    http://www.yamahaoutboardparts.com/f...tml#post131712
    to remove the sleeves I carefully use a small side grinder and thin it some.
    then I use a very sharp screwdriver and split it.
      Thanks, that post is very helpful.
