2006 T8 PXR no fuel in float bowl.
Nikki carb.
Motor wouldn't start after 2 months.
After thoroughly cleaning the carb It ran perfectly for 2 days. Now it won't start. Fuel bowl is empty. I disassembled and rechecked float needle and it manually shuts off and on OK when I blow through inlet, but when reassembly it still wont allow fuel into the bowl.
Incoming fuel to carb seems to be OK unless the pressure is too low to open the float needle valve or the float adjustment is not correct.
Can anyone help me find how to adjust the float and also how much fuel pump pressure should be? Or any other ideas. Tank, lines and filters are cleaned. Non ethanol fuel is new.
Thanks,
Frank
Nikki carb.
Thanks,
Frank
