Let's say that a Yamaha Offshore model, when running at WOT at 5500 RPM, has an advance ignition timing of 40 degrees BTDC.
If there was a knob on the ECU so as to manually retard the ignition timing, (like we did in the old days using a distributor) what do you think would happen if the advance timing was retarded somewhat? Say I turned the knob to go from 40 degrees BTDC to 38/36/34 degrees BTDC. What would happen?
