I just purchased a new Yahama multifunction Speedometer PN/ 6y5-83570-S6-00) for my 1998 Yamaha 225HP Saltwater Series II,V6. Inside the Speedometer are four (4) DIP switches labeled 1,2,3,4 with switch no. 1 in the OFF position, 2 switch is ON, 3 switch is OFF, and the 4 switch ON. Can anyone in the Forum verify that these are in the correct position? I know the settings of these DIP switches help select my preference of showing speed in terms of mph or km/h,distance in terms of miles or knots . My preference is mph and miles. Thank you in advance for your help!
Speedometer DIP Switch settings
Multifunction tachometer DIP SETTINGS
Thanks for your timely response I will implement your advise tomorrow. I have the same question for the multifunction tachometer DIP SWITCHES OF WHICH THERE ARE THREE (3). The tach part no. Is6Y5-8350T-83-00 for the same Yamaha motor as mentioned above. Hoping to hear from you soon. Thanks in advance.
I am now wondering why there has been no update to the Yamaha rigging guide since 2012? None that I can find anywhere.
Originally posted by boscoe99 View PostThat is exactly what he needs.
Tried sending you a 2014 .pdf I found somewhere - large file, may not go.
Seems in 2015 they went to that g-d online "flash player" format?
Originally posted by fairdeal View PostI'm trying to be more careful with my advice....
Do you use drop box?
Hi!, I really need your help!
I've been reading the whole thread but I am really missed...
I am trying to do 2 different things, but unable.. hope you´ll be able to give a hand..
1.- With a 6Y5 I am trying to change from mph to Knots... I have removed the unit,.. and I am unable to find the place where the dips are suposed to be.. (Please take a look to the attached photo).. I also tried pushing the menu button but also nothing happened... ) what I am doing wrong..??
2.- My trim indicator does not work. or at least it doesn't move, always shows the bar almost full.. In this unit yes there are dips, and I have On, Off, on config. But again nothing happens.. Engine is a Yamaha 250Cv from 2008..
I´ll reeeeaaaally appreciate your help!!
1. I think if you pry out - carefully- the rubber plug on the right
(the plug with only one black cable)
you will find the dipswitches below it
Try to slide the grommet on the cable, without pulling on the cable itself -
so the cable does not come unplugged, or its small wires torn:
2. Have you raised up the engine, and found & examined the trim sender device?
If it always reads full up,
the 'arm' may be broken off the sender
or, if that model also uses a 'cam', it may be mal-adjusted or broken
