My old trustworthy 1994 txrs 200 hp lost a cylinder today after many years and many hours of faithful service . Went into a partially seized moment after dropping the cylinder. Got good compression on the remaining 5 and 0 on that one. Bolt removal looks like it will be the issue...soooo.... what happenened and what to do. All 6 plugs look perfect. 80 n sunny.
worth repairing?
Partially seized could be from fragments of rings/pistons - started out as larger fragments, then got chewed up and spit out.
Pull the plug and stick a scope in there.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Just got the boat on the lift a couple of hours ago. Water jacket part of the head came off easy, but head bolts are gonna need some heat at best.
When I spin it up, not hearing air escaping and plug on that cylinder looks perfect. Will put the torch to it tomorrow . Got limited tools and resources where I'm at.
Salt water. And looks rough under the hood. Seeing the plugs look so perfect, maybe the oil pump failed? Not looking to be drilling n tapping for the next week or 2.
Would like to replace with something similar that I could make use of my lower unit and other parts. I'm sure pulling the power head would be a beast. Like said....got limited tools and resources here
I agree!...if you could find a very similar motor that's running O.K., buy it and keep your old one for spare parts....spare lower unit, carbs, electricals, etc., etc.Originally posted by scofflaw View PostSalt water. And looks rough under the hood. Seeing the plugs look so perfect, maybe the oil pump failed? Not looking to be drilling n tapping for the next week or 2.
How good would that be!....Try to find a similar freshwater motor....
I would repair it.Originally posted by scofflaw View PostMy old trustworthy 1994 txrs 200 hp lost a cylinder today after many years and many hours of faithful service . Went into a partially seized moment after dropping the cylinder. Got good compression on the remaining 5 and 0 on that one. Bolt removal looks like it will be the issue...soooo.... what happenened and what to do. All 6 plugs look perfect. 80 n sunny.
