Looking at the pics from the mechanics manual, I couldn't find a reference for just purchasing the seats alone. With something of this quality, it seemed like the seats could be removed and replaced. The pics from Boats.net on this website don't mention a needle valve seat. Probably something real simple that I'm just missing. Figure I'm probably going to feel like an idiot.
Yamaha 150 TRXC vibration issue
Originally posted by 99yam40 View Postflooding carb is washing out carbon and oil from cylinders and exhaust.
It's also very possible the crankcase is now full of fuel...Pull all the plugs and spin the motor over(pull the safety clip to kill the spark). If you have an air compressor, some spritzs of air will help dry it out...
Rodbolt posted previously how to repair the needle seat, IF THAT'S leaking. (I forgot-do a search)
I don't know if you can replace the seat itself..
If the needle is hanging up for some reason, re-check how it attaches to the float. There's often a very small spring between the two...
With that flooding, I would at least pull that carb NOW and check that needle/seat etc. You don't want a hydraulic lock and destroy the engine..
Also, that mix will NOT hamper starting of your engine, (it simply flooded).
I've run that mix in my 600cc bike and couldn't tell the difference(running/starting wise)Scott
Engine sat overnight and starting work this morning. Plan to pull all carbs and do a complete cleaning job. Good thoughts on flushing out engine before trying to start again. My fault on flooding engine, should have known better but never happened before. Did find that the oil intake was set a little on the high side (pump lever arm about 1/8" above seat with engine off). I'm thinking that even the small amount of the RF solution I got through the engine really began a good cleaning process if the black sludge out the exhaust is any indication.
Success! As suggested, I left the RF solution in the carbs/engine overnight. Main problem appeared to be leaking needle valve seat(s) in #3 carb. Priming engine in morning revealed tight valve seats and no leakage. Applied pressure to priming bulb for a few minutes to be certain leak was fixed. Removed plugs all of which had varying degrees of black gritty stuff. Disengaged spark as recommended and turned engine over a number of times. Turned water on to muffs and started engine using recommended RF solution. Ran engine at about 1800 rpm for about 5 minutes then increased engine speed to 2100 rpm where the vibration had been noticeably worse. Engine vibration did increase and engine speed would vary between 1900 - 2100 rpm. With time (about 30 minutes), engine vibration became noticeably less and engine speed slowly increased without throttle adjustment to 2300-2400 rpm. Backed off throttle to 2100 rpm and let engine run for another 15 minutes until about 4 gallons of Rf solution fuel had run through engine. Placed engine in idle (750 rpm) for a few minutes and shut down. I'll leave the RF solution in the carbs overnight again then run a little fresh gas through the engine but, at this point my problem appears to have gone away and the engine has never run so nicely. I am grateful to this Forum for their good direction. Hopefully, this experience the recommendations received will help others with similar problems.
Originally posted by Psalm 99 View PostSuccess! As suggested, I left the RF solution in the carbs/engine overnight. Main problem appeared to be leaking needle valve seat(s) in #3 carb. Priming engine in morning revealed tight valve seats and no leakage. Applied pressure to priming bulb for a few minutes to be certain leak was fixed. Removed plugs all of which had varying degrees of black gritty stuff. Disengaged spark as recommended and turned engine over a number of times. Turned water on to muffs and started engine using recommended RF solution. Ran engine at about 1800 rpm for about 5 minutes then increased engine speed to 2100 rpm where the vibration had been noticeably worse. Engine vibration did increase and engine speed would vary between 1900 - 2100 rpm. With time (about 30 minutes), engine vibration became noticeably less and engine speed slowly increased without throttle adjustment to 2300-2400 rpm. Backed off throttle to 2100 rpm and let engine run for another 15 minutes until about 4 gallons of Rf solution fuel had run through engine. Placed engine in idle (750 rpm) for a few minutes and shut down. I'll leave the RF solution in the carbs overnight again then run a little fresh gas through the engine but, at this point my problem appears to have gone away and the engine has never run so nicely. I am grateful to this Forum for their good direction. Hopefully, this experience the recommendations received will help others with similar problems.
I run RF regularly in EVERY gas machine, (truck, bike included) I own. Reg mix unless there's an issue.
Many folks are skeptical of "snake oils", but as you've seen (and your improvement is more than I would have expected), it does work...
Using it regularly and a stabilizer (not cheap) but IMO, is well worth the preventive maintenance aspect, lack of later issues, etc, is well worth it.Scott
Â
