Throttle and gear cable set up on 1985 yamaha 115etlk
  • Throttle and gear cable set up on 1985 yamaha 115etlk
    I installed a 115 yamaha outboard on my boat. It seems to run good, but I have trouble on take off and it does not want to engage into reverse correctly. I believe this is because I changed the cables and they are not set up correctly. I can't find anywhere on how to set up the cables so they engage correctly into reverse and forward. Also, I can't find how to set up the max throttle stops correctly and all that. Can anyone help me please....
    for the shift.
    remove the cable from the slide.
    line up the center of the slide with the dot on the casting.
    adjust the cable end to fit.
    on the throttle side.
    leave the idle timing/stop screw alone.
    leave the WOT timing stop screw alone.
    if this is a salt water motor inspect the shift shaft between the case and the midsection for hourglass shape.
