CL+ Gauge Only Showing Two of Three Tanks
  • CL+ Gauge Only Showing Two of Three Tanks
    Just completed a repower and got the newest CL+ rectangle display. It only show "bars" for two tanks.
    I have tanks 1, 2, and 3 active and all set to 80 gallons and abyc 4th is set to unused.
    Any idea what my problem might be?
    Thanks.
    The CL+ display carries a 6Y9 prefix. It is in color.
    The 6YC display is the cheaper version and is in black and white. It is not a CL+ display.
    When you (the OP) says you have three tanks active are they all fuel tanks and are they all set as fuel tanks? If so, check the grounds. All three tank senders have to be grounded in two places.
    The ground wires from the display have to be connected to the sender ground and the sender ground has to be connected to the ships ground.
        what a difference a + makes....
          And a C and a 9.
            And a C and a 9.
            I have a 6Y9 then. It's color and not the cheaper one. I have all three set to fuel.
