Two 2004 F225's with 180 hours on each. The boat and engines have been stored inside for most of their lives and are spotless under the cowl.
I bought it last fall and have run it approx 40 hours since then. The Starboard engine is flawless under all conditions.
The Port engine is possessed and has a few issues. I will address one of them here. Namely, about 50 percent of the time, the starter will not engage.
The 2 batteries are fine and the Starboard engines always cranks,
The anodes and connections at them are clean.
Two battery selector switches. OFF/1/BOTH/2 variety. I have NOT pulled them and checked for corrosion at their terminals...yet.
The large 12V connector at the starter is as new. No corrosion.
I pulled the starter and took it to a local reman shop. They benched tested it and said that its fine with no issues...."Looks brand new in and out" was his comment. He suggested the relay.
I replaced the relay. The connectors were spotless.
I then hooked up a test light to the relay, the right side always ON, the left is ONLY on when the relay signals the starter and as the starter spins. That should be obvious I suppose. BUT, every time I turn the key the relay will CLICK but only sometimes does the starter engage. When it does not, there's a click and the test bulb is not powered. Why is this?
Someone has added a remote start switch on the engine utilizing a jumper and a push button switch. It does not look like YAM did this at the factory. The engine will ALWAYS crank using this remote switch. Always. Thinking that perhaps this was the culprit, I removed it. No change. I still only get a crank about half the time. What could be causing this?
***I also have an issue with the low pressure lift pump not keeping the VST full, well, at least that's what I THINK is happening. About one half of the time, the engine does not like prolonged idle (no wake zone) and will cut out. I re-prime the squeeze bulb and it fires right up and off we go. I keep it above 1200 rpm and throttle the other back to idle (to keep my wake down) to keep it running. I mention this because of the ground.
I understand that the lift pump runs part time and is always HOT, but grounded by the ECU.
Is it possible that I have a wonky ground somewhere?
Because, In the most inaccessible spot imaginable (deep in the bilge) there are 3 large electrical connections from the engines bolted together. There are large gauge leads coming from the engines and they are bolted up here. Today I am going to TRY and access them, pull them apart and thoroughly clean them and give them a light coat of dielectric grease. They appear dirty. Could lousy grounding be at the root of all this crap?
Regarding the low rpm stalling issue, I have -
Changed the Racor, first stage and F Filter, I'm running fresh gas.
Pulled the VST (it was spotless), changed its screen,
Swapped the in-line check valves below the F filter,
Added new Yam squeeze bulbs, trimmed and re-clamped all the fuel lines,
Checked the 2 pins on the lift pump connector,
Checked the 3 pins on the (R, R/Y, R/Y) other fuel pump / injector connector.
I know this was a lot to read, but I hope to spare you from asking questions and to give the best info possible.
Any leads or advice is appreciated. I have been scouring Google for advice and that's how I found this forum. Thanks in advance.
Steve
Steve
