2015 Yamaha f150xb with command link
  • 2015 Yamaha f150xb with command link
    I bought the Command Link 1 gauge round kit part# 6Y8-0E83R-81-00. I have not installed it yet do to deciding to rig my new boat with a multifunctional sonar/chart plotter( Lowrance HDS 9/7 gen 3 boat package). I still want the tachometer for for reliable engine hours and RPM info but what parts do I need to buy to make the happen? The motor is a Yamaha F150xb 2015 with a side mount control. Can I buy a main bus hub and power harness and use the existing bus harness capping the yellow and black power wires or do I need to buy a new one? Any help would be much appreciated.
    I'm not understanding; what is your "existing bus harness"?
    Puzzling because you bought a Tachometer "kit" - and haven't yet installed it -
      I think the issue is that the OP bought the kit that does not use a hub. Without the use of a hub, if one uses Command Link gauges, there is no place to connect a Lowrance type harness so that engine data can be conveyed to an NMEA 2000 device.
      I suspect that he is wondering how to finesse the system. Not sure however.
        Here is what might work, if I am guessing correctly as to what the OP is wanting to do.
          Thanks, I think that is what I am looking for. Dont really want to buy new wires so I think I will buy the multi hub and resistor and try it with whats already in the kit.
            Let us know if this works for you please. That is how we learn a bit.
