I give up. I have a 2007 200HP Yamaha HPDI that I have been troubleshooting for a while. The motor will crank right over and run for about 3 – 10 seconds then shuts down. A little history on this motor: I bought this boat used. The motor only has 28 hours on it. It sat for 8 years with bad fuel in the tank and fuel system. I am sure that the previous owner left old fuel (ethanol) in the tank for this entire time and had tried running bad fuel through this motor since it was new. The fuel system was a wreck and had to be completely cleaned and components replaced. I had the motor running in the yard after my initial cleaning and repairs, but when I went to launch it the problem with the shutting down started. For the few seconds it runs it sounds great, then just shuts down on it’s own. Now for what I have done so far.
1- Cleaned the entire fuel system.
2- Cleaned and flushed fuel tank and installed new fuel lines and pickup, filled with non-ethanol fuel.
3- Replaced all filters
4- Replaced the Electric fuel pump.
5- Replaced the 2 diaphragm pumps
6- Had the High Pressure fuel pump disassembled and cleaned and all (Mystery ) filters replaced
7- Fuel rails and injectors cleaned
8- Swapped O2 sensor, HP Fuel Sensor with known good.
9- Adjusted the TPS and swapped it with good.
10- Tried new ECU
11- Tried new Injector modules
12- Checked gap on the Crank Position Sensor
13- Fogged the engine with Evinrude Engine Tuner
14- Swapped out ignition switch.
15- Swapped kill switch.
16- Tried auxiliary fuel tank.
17- Hooked up Diagnostic computer and no error codes.
18- Cleaned VST, float and needle valve, pressure control valve.
I am out of ideas. Can anyone help?
10- Tried new ECU
