I am in Bahamas, slow to get parts. I had the powerhead off and there was a defect in the base gasket that I ignored, but it is a problem with water and exhaust bubbling around the powerhead from one spot. Would it be a good fix to cut out a section of gasket and fill with blue silicone gasket maker?
The next possible problem is that large ants lived in the cooling system. This plugged up the tell tale, but then was finished. Do I need to worry about an ant nest plugging a section of cooling? Will it self clean?
