I can't find any good info, despite energetic Googling -
but I'm sure Rodbolt -between his Navy electronics and Yamaha school has the answer:
ok, we are told on an excited field alternator, the voltage regulator controls the amount of excitation. Seems fairly simple.
but
on our permanent magnet Yamaha alternators - where the voltage regulator is a "shunt" type -
when it is "limiting the alternator output" how exactly is the regulator doing that?
(obviously also creating heat as a consequence)
Is it using less of the waveform? (sending part of it directly to ground?)
and - for us Ohms law challenged -
how does con*****ing based on the voltage result in less amp output
but
