Hey Crew!
New to the forum, so first off, handshakes all around.
I've been searching here and everywhere on the internet for a couple days to try and figure out what's going on with my boat, but I'm stumped now and I'm hoping someone here can help me figure this out. I'll try to be as detailed as possible.
Boat hasn't been ran in a few months, so I wanted to put it on muffs and warm it up. It started with no problem but only ran for maybe 30 seconds. Went into alarm and bogged down.
Tried to restart the engine. It would turn over but not start. Pulled the kill switch and re-installed. That somehow cleared the alarm and the engine fired right up like normal, but went into alarm again and bogged down. Same alarm.
I really dont know what else to check from here. Im thinking one of the oil sensors went bad, but the alarm should go away if I unplug the wiring harness correct?
Couple other things that I can think of:
If I pull the kill switch, it must reset something in the ECU, because it will fire right up every time I do that, but if the alarm is still present the engine will not start. It will turn over though. That confuses me.
If I do start it with the kill switch trick, it blows a good bit of bluish/grayish smoke at start up. Maybe from turning it over without actually firing off. I dont know. Engine sounds normal until it enters limp mode and dies.
Any help on this would be greatly appreciated. I have pictures, but for some reason it kept failing to attach. Tried JPG and JPEG formats.
- Middle Bar Blinking on Tach
- Constant audible Buzzer
- Both oil tanks full
- Drained Fuel/Water separator and VST, No Water present. Re-primed.
- Drained engine oil tank and watched the pump refill it from the primary.
- Disconnected oil sensors one at a time to see if it would clear alarm. Did NOT.
- Removed sensors. Both were very clean as well as the oil that came from the tank.
- Wiggled the throttle around thinking maybe a position sensor. Did nothing.
