Hello,
I'm new here and this is my first post and I have a part question.
Quick explanation of my problem.
I noticed I wasn't getting any water out of my tell-tale when running my motor on my motor flushers (super technical term). I traced the hose from the tell tale back past the fuel cooling rail to make sure it wasn't clogged and when I went to pull the hose off the barb the whole barb came off in the hose. On the piece the barb went into there was silicone or some type of adhesive where the previous owner had patched it.
The part in question is circled in red on the parts diagram and I also added a close up picture of the part. It looks like it's badly corroded and is going to be fun to get out.
Any idea what this is called and where I can get a replacement is greatly appreciated.
EDIT - I forgot to mention the motor in question is a 2004 F150 TXRC 4 stroke
Here is a list of things I am going to check / replace
1. Pressure relief valve
2. Check spark plugs
3. check anodes
Ordered
1. water pump kit
2. thermostat
3. check anodes
Ordered
1. water pump kit
2. thermostat
I tried twisting the piece with some vice grips and no joy, that sucker won't even budge. It appears to be copper so I don't want to tear it up trying to get it out.
