there are no lead bb's for accessing the fuel passage on that 115.
what the tech bulliten says is hook up a water supply to the inlet,hold the carb upside down and turn on the water.
look for equal flow from the needle seats.
however if you tilt the carb any direction it tends too change the pattern.
if your carbs do not have the clean out port it can be added with the kit from Yamaha.
mostly a waste of time in my opinion.
