Good compression. Good spark, Cleaned fuel filter and lines and tank. Carb disassembled, soaked and new parts kit put in it. Removed high speed tubes, idle valve before soaking. Not really dirty, just the usual carb cleaning job.
Motor starts on the second pull with choke. It will idle low until it burns up the fuel from the choke then will not idle below about 2500 RPM. Sounds like a blockage in the idle circuit right? took the carb back apart, ran a wire through all passages, resoaked and cleaned. Same problem. Not spitting out the carb at all, good suction at the throat. Still wont idle below 2500 rpm.
the idle mixture screw doesn't have any impact whether completely closed or open 5 turns.
Was looking for crankcase leak but nothing obvious. Clean motor. disconnected the kill switch as well.
Open to ideas please? worked on many many two stroke carbs before but never had one like this I could not fix.
