Originally posted by pstephens46
View Post
https://www.amazon.com/Motion-Pro-08...ycle+tire+iron
Getting them warmed up in the sun or in the warm house helps too...
Re the drive shaft, your probably working at a work bench with a vise..
Clamp (with aluminum in the actual clamps)the drive shaft so the LU is hanging downward.
Either a BOX wrench tapped down on the collar or as previously noted, a flat piece of thick aluminum or steel drilled out and then tapped downward I'd think would work...
