I recently bought a 2005 150 Vmax HDPI and have a question about the tilt. The first time I went to use it, I picked the motor all the way up to remove the transom saver and the tilt solenoid just clicked when I went to press it to go down. I was able to lower the unit with the bleed screw. I get to launch and the motor went right on up, but I bled it once I got into the water. Once I got into the water and started the boat it worked fine up and down.
The boat has been sitting for 2 weeks and Sunday I went and pressed the tilt buttons and it only clicked to go up but down the pump worked going down.
I read on another forum that low battery voltage could be an issue, so I charged the battery and it seems to work both up and down now. Once I press the switch it does click first but does go up and down.
Is it true that the battery voltage has this much to do with operating the motor or does it mean my solenoid is about to fail?
