I have a 2004 Yamaha 40 hp 2 stroke outboard. I was greasing an alemite on the lower unit and the grease gun got stuck and the fitting eventually broke off. Is this a part that can be replaced at any part store and screwed back in? It looked like it could have possible sheared off and I wasn't sure what I needed to do. Any help would be appreciated. Thanks in advance.
Broken grease fitting
Yes it can. The grease nipple is called a zerk fitting. It can be purchased at your local yamaha parts dealer. Inexpensive, $3-$6. Most dealers keep these in stock because of exactly what you experienced.
Obviously you'll want to carefully remove the threaded fitting that remains seated so to not strip the threads.Last edited by Jason2tpa; 11-29-2016, 11:06 PM.Jason
Once you remove it (or another easily accessed one), you can double check the threads. It's best to get a stainless zerk fitting. Where you get it doesn't matter, but of course the "easy" thing is to buy the Yamaha part.
FYI, many grease guns have an adjustable tip. The part of the tip that goes on the fitting can be screwed one way or the other to make it "grip" tighter or looser. Just in case yours has that feature and you didn't know it.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I have a jar of various zerk fittings, some straight, some 45 degree angle, some threaded and some press fit.....I've had good luck with the pressed in fittings and it eliminates the need to drill and tap a small hole in a sometimes tight area.
The pressed in fittings have little ridges made into the press in part so they tap in and stay tight.....
It's definitely threaded, both male fitting and female receiver. Doesn't matter the brand you use, so long as it's the correct metric size. But being that a yamaha zerk fitting is so inexpensive, if you buy yamaha you rule out any chance of buying the wrong generic fitting. Call your local yamaha parts dealers and ask if they have the part number in stock. Find the part number here, #13:Originally posted by CCDAWG94 View PostWill just a standard 6mm zerk fitting work from a local part store or does it have to be one from Yamaha? I assume its one with threads but its hard to tell because the threads sheared off.
2004 40TLRC Yamaha Outboard BRACKET 1 Diagram and PartsJason
The hard part may be simply removing the old part. IF it's NPT, it's going to be friggin tight.
Normal thread, not as bad once broke loose...
It's already got a hole down the middle, so hopefully the right sized "easy out" would work..
And make sure you use a SS replacement fitting..Scott
It wouldn't be corrosion I was looking at. If it's NPT thread, tapered, it gets tighter the farther in it's installed. If it simply bottoms out (the hex"head"), it just needs to be cracked loose.Originally posted by Jason2tpa View PostIf greasing had been maintained, you'd think corrosion wouldn't set in too bad around the threads. .Scott
