Long story trying to be short. When I bought my 2005 F90, the owner had it for 89 days and had used it twice. I though I had hit the jackpot. That was in 2006. Since then I've had problem after problem with the motor. I have done routine oil and lower unit lubes and had routine service performed by a dealer. Last Friday was the proverbial last straw. For the third time in two years the motor started idling at 2000PM and shifting very hard due to high RPM's. I was about 10 miles offshore so forced it into gear and hightailed it back to the ramp. Put it in the shop Saturday morning. First time this happened it cost me $2200, that was for a new wiring harness and a lower unit rebuild caused by forcing it into gear so I could get back in, didn't work anyway and Sea Tow ended up towing me about 14 miles. About six months later the high idle problem came back. I took the motor into the dealer who replaced the Wiring Harness and was informed that I needed another wiring harness, I was also informed the Yamaha doesn't warrant electrical parts and that the dealer is prohibited from repair on the wiring harness. After I raised a sufficient amount of rage the dealer agreed to fix the harness and did for only $125. Kicker is they repaired it with a piece of my original harness they had kept from the first replacement. The exact problem repeated last Saturday and I can't wait to hear the diagnosis and estimated repair costs. The list of repairs I've had done to this motor is ridiculous. I haven't abused it and probably average 100 hours a year on the motor. My dealer tells me that there is a known problem with the F90 Wiring Harnesses, so why doesn't Yamaha do something about it? Anyway I'm certainly not a Yamaha fan and my boat is going on the market as soon as I get it out of the shop. I've spend between $4000 and $6000 on various repairs, none of which resulted from abuse. At this point I no longer have any confidence in my F90 and certainly am not going off shore again with it. This is the end of my rant. Bottom line for me is if the Wiring Harness problem is known to Yamaha? Why haven't they done a recall or a tech bulletin or something. I don't think that a $695 part plus labor is something that F90 owners should just accept.
FLCoyote
FLCoyote
