Originally posted by boscoe99
View Post
Hard Starting
Sorry, I don't have a clue as to why the differences. Other than a two stroke has the ability to create pressure pulses to help move gasoline whereas a four stroke has to depend on a pressure differential created in the carburetor.Originally posted by TownsendsFJR1300 View PostThanks.. Do you know what (generally-less volume?) would be different and why between the 2 and 4 strokes? (just curious)
the thermal part is what shuts off the fuel flow after the motor warms up.Originally posted by Eastexn1 View PostThanks to the great drawings I think this problem is about solved. Looks like the thermal enrichment device is not working.
Thanks to everyone.
So I do not see how that could be the problem with motor not starting when cold.
problem with the thermal heater would be a problem with it running too rich after warm up
Thanks........Originally posted by boscoe99 View PostSorry, I don't have a clue as to why the differences. Other than a two stroke has the ability to create pressure pulses to help move gasoline whereas a four stroke has to depend on a pressure differential created in the carburetor.
.Scott
the carbs for a two or 4 stroke work identically.
it uses a colum of air that at se*****l is about 14 miles high.
pulse pumps work on both two and fourstroke engines.
they have been around for years.
most large 4 stroke motors use another carb circuit called an accelerator circuit that most two strokes do not need.
Yes it was.Originally posted by 99yam40 View PostI believe this was referring more to the prime start enrichment system than the way the carb itself worked
Is the prime start any different (basic operation) between the 2 and 4 stroke?
I would think just the volumne of air going thru ANY carb(cranking), (2 or 4 stroke), with the prime start "activated" would allow extra fuel to be sucked in
Just an educated guess...
.Scott
