Do I need to run my 2007 90 horsepower 2-stroke Yamaha engine to get lubricant into the cylinders for winter storage. I've treated my fuel for winter storage already. This is my first Yamaha engine but in the past on my older Mercury Motors I've used a spray bottle with full strength seafoam gas treatment, cranked the engine, not started, and sprayed seafoam gas treatment into each cylinder about 4 shots each. Any feedback on this procedure will be appreciated.
getting winter storage lubricant into the cylinders
no they do not.
reeds can corrode.
wristpins,crankpins and all the other shiney metal parts can rust.
MUST do it through the intake system.
seafoam is NOT a long term storage oil.
buy a can of fogging oil.
remove the air box.
start the engine and allow it to warm up making sure adequate water is supplied.
now move the warm up lever to get about 1100 RPM.
spray about 1/2 the can equally in all the carbs.
idle it down shut it off and that part is done.
the only two reasons to winterize a two stroke outboard are 1 protect the fuel system.
2 to protect all them thar close tolerance shiny metal parts inside.
salty dawg that I worked at used to be in Manteo NC.
it is now condos.
we had roughly 300 boats in the dry stack and about 60 or so in outside racks and about 30 in slips and I was the only tech.
I stayed rather busy.
salty dawg was a shamrock dealer,yamaha dealer and a Volvo dealer and a mercrusier dealer.
Originally posted by rodbolt17 View PostI have done that in a pinch.
we had a few customers at salty dawg marina that did not use the boats much.
that is what we did before putting them back in the stack.Scott
Originally posted by panasonic View PostFog the engine as Rodbolt says, cant go wrong.
I'm in SW Florida, there is NO winterizing when mid winter it warms up to mid 70'sF, water temp about the same..
It's about 82F right now and sunny.Scott
ÂÂÂ
