I need a product that I can use to spray down my engine and not worry about electrical components. Anybody reccomend a good product. There's so many out there and don't have experience with them. Basically I want to spray down the entire engine including hoses, engine block, electrical components and plastic/metal to prevent any corrosion and protectant? Thank you
Corrision protection
Originally posted by DennisG01 View PostI'm sure this is not the only good choice out there, but I've being using Boeshield T9 for many years and really like it.I agree with both. However, If you have an engine with an O2 sensor I would be careful not to spray silicone within your intake and on/near your 02 sensor cover, as it has been said that silicone can foul the sensor.Originally posted by fairdeal View Post
I do have an 02 sensor in my engine and have used Boeshield T9 for years successively. It may cost about 15-20 bucks, but doesn't take much and lasts a long time.
Others have said DON"T USE WD40, I would not.Chuck,
Simple Green is what I use on the block and lower cowling pan, excellent results.
You should not spray any corrosion solvent, degreaser, etc, directly onto electrical components. There are many solvents specifically made for electronics, so it's one of those you'll want to use to clean up electrical connections/tubes/wires.Jason
