Need wiring colors for T & Trim gauge 2010 40 hp 4 stroke outboard
2010 Yamaha tilt & trim analog gauge wiring hook up
The main sender pink wire is part of the engine harness. A separate Yamaha harness is used to get the trim signal (plus the low oil pressure and over temperature grounds) to the dash.
There is a pink wire in the main ten pin harness that runs from the motor to the key switch but that is for the alarm ground.
