'98 S115TLRW
Beautiful day today here in Tampa, not such a successful boat day. I experienced a low oil level alarm today followed by RPM reduction, etc. First time this engine has alarmed since I've owned it. The diagnosis would be simple if the oil level was actually low...but that would be too easy, right. Once I got the alarm I shut down, verified the remote oil tank was full which it was. Popped the cowling off and saw the engine oil tank was at the lower level mark, which is where it's always been every time I've looked in the past.
My tach doesn't have the red, yellow, green markings. But if it did, what I'm seeing on the tach during this alarm is a solid red bar, blinking yellow bar, no green bar.
Soo, where to start the diagnosis? Boscoe...I searched the threads to find some assistance and came across a similar posting as mine. Took a snap shot of your reply. I've attached a pic of your response, along with a pic of the type of tach I'm using. Quoting you, "the horn can sound a low oil alert yet the oil pump might still have sufficient oil to supply to the motor."
Since this alarm isn't truly sounding because of low tank oil, either in the remote or engine oil tanks, i'm left to assume it's an electrical issue, failed remote oil level sensor?? The low oil alarm sounds only because its detected "low oil", not a failure with the delivery system (pump). Right?
If the low oil alarm is sounding with a full oil tank, what are we talking about here as the culprit of this alarm?
