i bought a boat with a 92' yamaha pro 50 outboard. Im having some trouble diagnosing the problems, because the motor has been modified a bit.
first problem is when it idles cold or warm it has what sounds like a miss that kills the engine. It will run for about 30 seconds perfectly smooth then hits a dead spot and dies. I set the CDI box to factory specs, and it didnt help.
The motor has good compression, and good spark. The head is slightly milled but I dont know if that would affect anything.
The second problem is it sounds like it is flooding out when I roll the throttle through slowly. If I go straight to full throttle it gets up and moves!
He told me the carbs are over sized which Im guessing could be part of the problem.
The last and final thing is, at top speed the engine almost sounds like it is gargling and losing a tiny bit of power.
im running 160 main jets and my plugs look bronze like they should. Ive tried tuning the fuel/air mixture screw to manuels spec, but they aren't stock so im not really sure where to go from here.
any ideas on solving some of these issues would be greatly appreciated.
