Hi all.
Has anyone tried to swap the middle carb with a upper or lower ?
Let me explain.
Yamaha 70 : 3 carbs :
Cyl 1 upper carb
Cyl 2 middle carb with enrichment
Cyl 3 lower carb
Has anyone tried to remove the middle carb with enrichment and to install a
(lets say) a spare carb from cyl 1.
So it will be 1-1-3.(upper-upper-lower) In this set up the prime start will be disabled as the middle carb is removed.
Will it work ???
Stupid as may sound, has anyone tried this setup??
What about No.15(90445-07M02-00 diagram) hose that goes from middle carb to body and another hose No.17 (6H3-14349-00-00 pipe)
Let me explain.
Cyl 1 upper carb
Cyl 3 lower carb
Will it work ???
