my lift cylinder is leaking. can it be re sealed or do you just replace .
F 225 leaking lift cylinder
Trim/Tilt assembly?
Have a look at video at bottom of this page.
Pin Wrench - AMT0004 - 38mm X 4mm
Mine is leaking from back of unit. Different issue. Make sure you know where the leak is coming from.Last edited by pstephens46; 10-01-2016, 09:34 AM.
it appears to be coming from where the cap screws into the housing.the large lift cylinder not the two smaller trim cylindersLast edited by marchmadness; 10-01-2016, 04:47 PM.
