So my flow meter saga continues. The flow meters continue to get clogged from varnish and I have located the source. The fuel lines from the flow meter output to the engine is the culprit. I tap them and sure enough a continual flow of varnish gets dislodged. Since there is no check valve between the engines and flow meters I suspect the varnish is backing into the flow meters. Time to replace the lines.
Is there a Yamaha part number for that fuel line or can I just use standard marine 3/8" fuel line?
