Originally posted by CaptSolo
Finally stored a Code 46! (whiskey tango foxtrot)
Fairdeal
Professor Fairdeal- did you do anything to try to repair the above corrosion? I have heard about people using JB Weld etc. but would be concerned about breaking loose and plugging somewhere.Originally posted by fairdeal View Post
I was extremely fortunate to "catch" the corrosion before it ate completely through
(alerted to the possibility by Boscoe's posts)
In the worst spot, there was only ~1/16" of metal left.
My fear with applying epoxy filler on the inside was that I could not be sure of a 100% water tight adhesion - in which case the corrosion would continue under the patch, the worse for being no longer visible..
My second stroke of luck was getting advice to use zinc chromate primer - which has an almost magical bond with aluminum.
As in any painting, preparation is key - I worked the inside relentlessly with picks, scrapers and a dremel wire brush.
I then reinforced the outer surface with Marine Tex, so I am confident I have structural integrity.
I since pull the thermostats 2-3 times /year to check, but the zinc chromate is so far unfazed by near boiling seawater.
the center of stat has some copper from what I remember.
salt or mineral bridge to the side will cause a lot more reaction.
pull and clean or replace often
Mine was bad enough that when I was cleaning the corrosion it went though and I had to have it welded up.
So far no problems
that is exactly my impression also.Originally posted by 99yam40 View Postsalt or mineral bridge to the side will cause a lot more reaction.
The thermostat - and I think all of it is some "yellow metal" -
doesn't actually touch the aluminum block directly.
But somehow white insoluble salt/mineral builds up in that cavity -
and its that wet conductive "bridge" that does the damage.
I wish I had taken photos when I first acquired my F225 - but I was too horrified to think of it.
The "salt" was packed so tightly, the thermostat actually tore apart being pried out.
And remarkably, the engine wasn't overheating.
I suspect it would "run cold" - suffer from poor economy and possibly "make oil"Originally posted by pstephens46 View PostI have known a few with smaller motors to remove thermostats completely. Wonder how this would work for F series motors?
Getting the thermostats out on the old six-throttle-body F200/225 is an irritatingly tedious job - it could have easily been designed differently.
But it simply needs to be done regularly.
The perfect battery, in our concern the perfect electrolysis storm:Originally posted by fairdeal View Postthat is exactly my impression also.
– An anode (negative charge), thermostat cavity (aluminum alloy)
– A cathode (positive charge), the thermostat body (copper/brass alloy)
– and the electrolyte, Pasty (wet), salt/mineral deposits
In the dry cell, Zinc is the anode (-), the graphite core is the cathode (+) and Ammonium Chloride paste acts as an electrode.
In my motor, the thermostat mounts on the head cover, others will be different . My motor the thermostat is a bit (quite a bit) easier than Fairdeal's to remove, inspect, maintain.
I believe the bore where the thermostat seats was originally primed w/zinc-chromate and second coated with engine grey. After time, the painted surface wears (including when we clean the bore) exposing the aluminum alloy surface.
A little extra maintenance, as Fairdeal did, seems to very worthwhile.
I usually just brass wire brush the bore and pop my thermostat in. Now, to think about it, I'm probably damaging the painted surface and causing more electrolysis.
Next time, a "Fairdeal Deal".
Thanks FairdealLast edited by cpostis; 09-27-2016, 11:44 AM.Chuck,
All water cooled motors with stats need them in place to cause the water to circulate properly.
without they end up with cold and hot areas. they were designed to have them in there, do not try redesigning a motor
