I have a 16ft Lakesport center console (750 lbs) with a 50hp 2 stroke. My WOT is 4000 RPM and 26MPH. I have a 10.25x14 stainless prop. I've been told by several people that i should be able to run in the mid 30s. If in neutral it will rev to 6k+. I was able to barrow a prop from friend its 11 5/8x11 with his prop i was able to get my RPM up to 5600 but my MPH dropped to 23.
Ive been told it may be a motor problem but she starts right up idles great and runs like a champ until she hits 26-27 at 4K.
Ive check plugs and shes getting spark on all 3 cylinders. Fuel screen is clean so i don't think its a carb problem i cleaned the carbs about a year ago due to not getting fuel turns out it was a bad fuel line from tank to motor.
IF anyone has had this issue your knowledge will be greatly appreciated.
