Hey guys I own a 99 Contender 28 with twin Yamaha 200hp Ox66's. The boat has been a one owner boat up until I bought it a few months ago, always garaged and maintained with an open checkbook. Motors have 700hrs on them and I think I have a max rpm issue. The motors run absolutely flawless. Never have given me one second of a problem. Idle and cruise speeds are perfect. I found what I think is a max rpm issue when testing props. No matter what prop I put on this boat the rpm's never go over 4800. As stated before the motors run perfect in every situation and never miss a beat, I just don't feel like 4800rpm is enough.
Last weekend I replaced the following and got the exact same result last night....
- VST filters - they looked perfect
- Spark plugs - looked good
- All low pressure pumps
- Pulled 02 sensors and had them professionally cleaned
- New Racor fuel/ water filters
What is throwing me is the motors run to the exact same rpm and do it at the exact same time. How could both motors be experiencing the exact same issue? IS there an issue at all? The reason I think there is is because there should be at least a few hundred rpm difference between the 19 and 21 pitch props, there isn't.
I know the manual says 4500-5500 is the correct max rpm but 4800 just doesn't seem right to me.
The only other thing I have noticed is I can still pump the primer bulbs with the motors running- they are not rock solid. Is this an issue? Doesn't change a thing when I do pump them. Thanks for any help or advise. Just want to make sure the motors are at their best.
