I am attempting to diagnose a problem that I have been having off and on that has been occurring on a more frequent note. I am having an extreme miss when driving down the lake, above 3500rpms to WOT. It occurs very randomly and goes away if I come off plane to an idle. Then I can occur as normal until it does it again. The boat runs as strong as it does when I bought it. I know its either fuel or spark, but haven't had much time to really put into it. Thanks! -LJ
1992 C115TLRQ Miss
Back to basic's, when were NEW spark plugs installed?
I had a similar issue on my 4 stroke (hestitation and the RPM dropping at 5300 down to 4800 or so). New plugs ONLY, fixed it, back to 5900 WOT..
Your symptoms sound like plugs... Easier to fire at idle, harder at higher RPM's, ESPECIALLY if WORN and the gaps OPEN UP from wear (misfire big time)..
.Last edited by TownsendsFJR1300; 09-20-2016, 08:01 PM.Scott
I'm assuming your in fresh water operating in a lake so salt build up in the head isn't likely.
With the pisser slowing, the alarm going off, the WP is the first thing I'd be checking. IMO, get a genuine OEM kit.
Is there much / any silt/ sand in the lake that could get sucked in the engine?
Also, is the engine carbed or FIed?
.Scott
