Looked for my old post on this one, but it looks like there are a week or two of posts missing.
Anyway I'll try and recap the best I can:
Out fishing one evening, ran to my spot ... no issues. On return motor bogged down and stalled. Restarted right away, bogged down when given throttle. It will start and idle fine. Drop it into gear and no issues. Give it a little more throttle and it will bogg down and eventually stall. If I 'play' with the throttle and bump it up a small bit, let the motor recuperate (from bogging down) ... bump it again, and repeat 4-5 times, I can get it to WOT about 60% of the time. Took it out today (to check timing) and was running 37mph across lake ... slow down, give throttle again ... boggs down.
1) rebuilt carbs late winter/early spring. This was preventive (had not been having any issues) and motor ran great afterwards on several trips this spring.
2) Replaced fuel pump (was going to do that over winter also ... but).
3) No change when running off auxillary tank vs built in tank.
4) Replaced fuel lines from conector to carbs
5) By-passed built in fuel filter (though may be it was sucking air).
6) Pulled carbs back off ... checked floats and jets.
7) Ohms for Pulser coil, crank sensor, charge coil, and ingnition coils all w/in range per Yamaha manual. Coils and coil grounds are tight also.
8) Checked timing (once I got my light to work) Retard timing 7 ATDC and Advance 22 BTDC.
9) Spark looks good on all 3 cylinders.
10) Also checked Ohm readings for CDI, per manual, and did have some that were slightly out of range. Now that I'm typing, I can't find where I wrote them. I will recheck tonight and post later.
Any other things to look at or check?? Can the CDI be checked in any other way, off the motor?? (I live 2 hours from the nearest Yamaha dealer). Right now I'm thinking the CDI is the issue ... but that is a lot of $$ if I am not sure!! Anyone have a good used one laying around??
