Hello,
On my last outing i noticed Battery not charging. After returning home put battery on charge. When charge completed I load tested battery checked ok. Battery cables just replaced last year. Operated tilt up and down a few times and ran engine with volt meter directly on battery and attached a amp clamp to positive cable. Found no voltage change from original 12.8 volts.
I then checked the 30 amp fuse for regulator ok. Then check voltage at regulator connector red and black wires checked ok measured battery volts.
I then disconnected the connector i believe goes to the stator coil. I checked resistance in between all three legs.
1 to 3 1056 ohms
1 to 2 528 ohms
3 to 2 528 ohms
Then i put volt meter on AC volts with plug disconnected and checked each leg one at a time to ground with engine cranking.
pin 1 .45 volts
pin 2 140 mili volts
pin 3 .45 volts
Also checked resistance to ground one at a time and results all open none shorted to ground or negative.
After this i think one of the coils have opened and that one controls charging. The other two are for spark?
Any input would be appreciated.
Thanks,
1 to 3 1056 ohms
1 to 2 528 ohms
3 to 2 528 ohms
pin 1 .45 volts
pin 3 .45 volts
Thanks,
