On another forum there was a question raised about varying voltage values being displayed on an MFD via an NMEA 2000 network, when the motor was running at a steady RPM. You offered a comment about the data being sent to the MFD via pgn sentences.
Do you happen to know the rate at which the sentences are sent? I can't find anything on the inner web about this.
It has got me to wondering. There are many sentences being sent continuously. Although electrons be quick, it will take some time to send a number of different messages. Let's say 100 messages. One of those messages is the voltage.
The R/R is also quick, given that it is also working with electrons. I am wondering if between the time that one voltage pgn is sent, say with a value of 14.3 volts, by the time the next voltage pgn is sent the value from the R/R might now be 14.8 volts. This might explain why the voltages seen on the MFD rise and fall.
What do you think?
What do you think?
