Starter switch relay
  • Starter switch relay
    Starter switch relay on Yamaha 1998 25ELH does not start when humid. When I put in the sun, it is ok. What part should be changed, if any?
    need to be testing to see what the problem is.
    switch, relay, wiring/connections, and starter
      Are you talking about item one in the illustration at this link
      1998 25ELHW Yamaha Outboard ALTERNATE 2 25EH ER Diagram and Parts
      Before becoming just a parts changer, as Yam99 says, verify that the relay is defective or not. Otherwise you may wind up with an expensive but unneeded spare part.
      The relay itself may be failing or maybe there is a problem with electrical power
      Getting to and through the relay and on to ground.
      The relay gets electrical power (to close the relay) from the key switch. The key switch gets its electrical power from the motor. The motor gets its electrical power from the battery. There are connections and wires along the way. It will be your job to trouble shoot the system to find out where the problem is.
      Also, don't forget to check all grounds.
        By the way, a starter relay does not start. It only closes to allow electricity to pass through it and on to the starter motor. The starter motor turns, or cranks, the motor to get the motor started.
        And it is not a starter switch relay. If anything it might be called a starter motor relay, when it is used to control a starter motor.
        Correct names matter so that we can all better understand the situation.
          Battery condition? Age?
          Has it been load tested? Start with A, move to B and so on....
