Hi,
My 90 hp Yamaha has started to spit out water from underneath the engine. it is literally pissing out. Has anyone else experienced this? My local Yamaha dealer had no experience with this but advised me to pull the head. The motor is used in salt water, obviously corrosion could be an issue
Can anything be blocked? Any advise other than pulling the head and see?
While running the engine on dry land using "ear muffs" no leak was discovered - this could possibly be caused by lower pressure from the water hose than the impeller can generate when at sea.
Experience from other users/pictures is much appreciated.
