My SX250 is overheating when over 1500 rpm. I've watched it signal over heat with the flashing temp blinking on the Tach, but it simultaneously sounds the alarm at the same time. Is that typical? both going off at the same time?
Can error codes be read of an OX66 SX250? Before embarking on replacing water pump, thermostats, pressure control valve..., it would be nice to read any error codes if possible.
Boat used in salt water, always flushed with fresh water for 30 minutes after every use.
Also interesting, motor cowling doesn't ever feel overly hot when alarm sounds. And, seems to take only 15 minutes of drifting (each time) to cool down so alarm and temp indicator goes off. The event consistency makes me want to consider electrical problem?
Appreciate any feedback. Thanks in adavance.
