Hi all, I have a 1986 yamaha 2 stroke with a 703 control box that wont shut off when you turn the key or pull the kill switch, only way to shut it off is to starve it of fuel. I have had a guy look over it and check and fix the grounding wires. It worked again for a few times, but is now back to not turning off, any ideas? He is suggesting a new switch but i don't think that is the problem after reading other forums. Thanks for the help.
1986 yamaha 2 stroke won't turn off
do you have a multi meter ?
disconnect the white wire at the CDI,test from the harness side of the white wire to the engine block with the key off.
should show 0 or very near 0 OHMs.
if not find the break in the circuit between the engine block and the white wire at the CDI.
ÂÂÂÂ
