2002 200 hp ox 66 , 1400 hrs . Need some help moving forward with motor running rough . Motor will shut of at idle after 4-5 minutes, increase idle and motor will stay running but after 4-5 minutes starts idling up and down by itself . Also , when trying to get boat on plAne 2will not exceed 3300 rpm needed to plane .i can ru. At low speed and one time it will plane out and run fine up to5100 rpm and the next time I try it will not get up on plane . I did spring maintenance including plugs,new filters, cleaned vst tank , o2 sensor . New thermostats . Since having problem I have done e following with no luck .
1. Changed all filters including external water separator, fuel bowl filter on motor , new vst hp pump filter, small screen filter on top of vst tank.
2. New primer bulb
3. Ran motor on external 5 gallon tank .
4. Remove check valve between engine fuel filter and low pressure pumps
5. Checked vacuum at low presume fuel pumps
6. 2 new low pressure fuel pumps
7. Checked fuel pressure at Scrader valve 35 with key on , 37 with motor running at all rpms .
8. Had injectors cleaned by the injector man .
I did all this after reading many post from many people on the Hull truth . I did post this info on their site without much response so I thought I would try somewhere else. I am almost to the point of saying Uncle! But thought maybe someone on this site can tell me if there is anything else to check before taking it to the boat dealer . Thanks for any help for the old man ,Greg
2. New primer bulb
