the issue im having is when testing my overheat sensors, my buzzers go off but my gauges do not flash overheat. i am suspecting the diodes in the dual keyswitch as the problem is the same on both guges/motors... any ideas or suggestions ??
Multifunction tach issue
The module in dual keyswitch will cause wierd problems however not sure about your problem. The temp light wire is in the trim/oil harness that goes between engine and tach. Some engines had a gray wire(temp light wire) at engine that had a bullet connector on it and plugs into the 4 pin trim/oil harness. You should be able to ground the gray wire at tach(with ignition key on) and make the temp light come on.
working on a sunday huh...i did have to repair that harness at the motor junction whereas the black wire was broken....oil level was flashing low when it wasnt,so i checked and lubed all harness ends and found the break.
thanks for the suggestion, will try tomorro evening, thanks !
