I have 2 stroke 225, been stored for some years, carbs have been stripped cleaned and new repair kits installed, new fuel and fuel lines installed, fuel pumps cleaned. engine starts then stalls as soon as you try to give throttle, if I disconnect the yellow wire at the bottom of the ECU it starts and will rev but still rough running. Yamaha technician says ECU?. Any advice guys? Thanks
Yamaha 225 2 stroke starting and running problems
Here are 5 shots I have
Engine plate and carbs kit replacement.
RodBolt, Ok I have been thinking it might be stuck reeds!! I didn't check them yet and I had the engine running with or without cdi connected. but very rough running, then overheat warning buzzer came on. My thoughts were always fuel starvation through the carbs. I can only check it next weekend. Do you have experience of this before? does it sound like a possibility?
ÂÂ
