I attempted to install the new gauges I bought from Boats.net Tuesday (6Y5-8350T-83-00 TACHOMETER ASSY and 6Y5-83570-S6-00 SPEEDOMETER ASY). The connectors on the new tach do not match up with the connectors on the existing trim harness. I contacted Boats.net and they said I needed trim harness 6Y5-83653-20-00 and gauge harness 6Y5-83553-N0-00, which I received a few minutes ago. I am perplexed because the trim harness only has one connector whereas the tach has two connectors. I contacted Boats.net tech support and they said I would be fine, that the other connector out of the tach is not needed for my application. Does this sound right? The wiring diagrams I have looked at show both connectors being used. I am 2 hours from the boat and I don't want to go there with the wrong harness. Thanks for any help.
New Gauges for 1993 200 TXRR
Those adapters only work on motors back to 2001.Originally posted by Elwood22 View PostHow about one of these adapter harnesses - 6Y5-85335-10-00 or 6Y5-85335-00-00 - would one of these work? Seems like that would be easier than fishing in a new trim harness.
If you are just replacing the gauges what happened to the harness that was in the boat? Why not just reuse it, the same as you are going to do with the other gauge harness?
The connectors on the harness don't match up with the connectors on the gauge. I may have given you the wrong answer on the connector type. They are round on the outside and square on the inside. Attached pic may help if I did it right. Thanks.Attached Files
You did. That is why I asked in the first place.Originally posted by Elwood22 View PostThe connectors on the harness don't match up with the connectors on the gauge. I may have given you the wrong answer on the connector type. They are round on the outside and square on the inside. Attached pic may help if I did it right. Thanks.
Yamaha made a significant change to the instruments and harnesses in 1994 when they changed from round connectors to square connectors. The diagram below shows how a 1993 and earlier model Yamaha is connected to 1994 and later gauges.
