Hi all,
I’m looking for some advice regarding voltage and engine temperature on a two stroke 1993 115HP V4 Yamaha outboard (model 6E5 - long leg - 115BET).
I recently purchased this outboard and have performed a complete service on it. Cosmetically it is in virtually perfect condition and looks new for its age. Upon starting it for the first time I noticed my volt gauge was reading rather high on the dash of the boat. What I would like to know is the following voltage and temperature readings normal?
I performed some testing to gather as much information as possible. As a result this will be a lengthy post!
All tests performed with boat on the trailer and flushing muffs providing cooling water.
Outboard idle speed (from connected tacho): 900 RPM
Compression Test
• Tested with motor warmed up – run for 15 minutes
• All sparkplugs removed
• Ignition disabled via safety lanyard removed
• Throttle WOT, lower unit in neutral
• Each cylinder cranked 2 times for same duration
• Outboard starts and idles perfectly (on muffs at least, haven’t water tested yet)
• Cyl 1: 125PSI, Cyl 2: 127PSI, Cyl 3: 130PSI, Cyl 4: 127PSI
So in terms of voltage readings I used a good quality multimeter at the battery terminals.
Battery has been fully charged via a smart battery charger several days before this test.
Battery at rest (sitting for a few days): 12.7 Volts
Battery cranking: 10.4 Volts
Battery voltage when outboard running (just after cranking at idle speed 900 RPM): 12.9 Volts
At 1500RPM: 14.6 Volts
at 2000RPM: 15 Volts
After 8 minutes at idle (900rpm): 14.4 Volts
After 15 minutes of running (taking reading at 900rpm idle): 14.5 Volts (dash volt gauge shows 15v)
How do these voltage readings look? I don’t want to boil my battery or damage any on-board electrical gear. I assume the outboard has a regulated rectifier? Is anything amiss? I was concerned with the 15 volts at 2000RPM.
In terms of engine temperature, I have two aftermarket temperature gauge senders installed into the Yamaha factory purpose made ports on top of the cylinder banks where they show to install pressure and temperature senders. Motor tell tale is very strong at idle.
Readings are as follows (on muffs):
After 8 minutes of running:
• Port bank: 58 Celsius (136.4 Fahrenheit)
• Starboard bank: 41 Celsius (105.8 Fahrenheit)
After 15 minutes of various engine speeds, but reading at idle after waiting a few minutes:
• Port bank: 59 Celsius (138.2 Fahrenheit)
• Starboard bank: 50 Celsius (122 Fahrenheit)
The port bank is noticeably warmer to the touch than starboard as per the gauge readings. I can hold my hand on the port side without discomfort. So far temps don’t rise any higher but the test only went for 15 minutes on the muffs with a garden hose.
I expected both sides to be more or less similar. No overheat alarms or anything. Again motor has not been run on the water yet.
So:
1. Anything out of spec here?
2. Should I be concerned with battery voltage or engine temperature at this point?
Edit: Forgot to mention I did a continuity test on the rectifier terminals with the engine off as per the OEM engine service manual. It fails most of the tests – i.e. I don’t get any continuity when the manual says I should. Only a few combinations pass the test. Multimeter set to continuity mode.
Compression Test
So:
