Lean out the fuel/oil mix enough and you won't be having an excessive smoking issue. The motor will be so quiet. It won't vibrate. It will be so smooth.
1997 40hp 2 stroke smoking bad
Originally posted by boscoe99 View PostLean out the fuel/oil mix enough and you won't be having an excessive smoking issue. The motor will be so quiet. It won't vibrate. It will be so smooth.Scott
Originally posted by ausnoelm View PostI guess you didn't read the bit where you were told NOT to play with leaning out the oil mix! It is 50:1 leave it that way, using less and less oil is just a method of finding how little the motor will run on before it stuffs up, and when you find that point, it's too late.....
I think everyone (at least I did) assumes its BLUE, excess OIL SMOKE.
Clarify please:
Is it BLUE SMOKE-OIL or
is it BLACK SMOKE (over rich fuel air mixture)?
Engines generally don't run RICHER over time (unless a float, float needle/seat fail).Last edited by TownsendsFJR1300; 08-21-2016, 04:23 PM.Scott
So i did a full service today and found that the pilot screws were 2 1/4 turns out, causing it to run rich. Unfortunately, I need a new impeller. I reset the pilot screw to 1 1/2 turns. I pumped the tank and added 50:1 mix with a touch of seafoam. No leaks in the fuel system. Started up first crank and wasn't pissing, so I'm going to swap out the impeller. Hopefully they have one here in town tomorrow
You may want to buy the entire kit to 100% performance. Its not much more.
Please post back how it goes..
I am curious how the screws got un-screwed so far, especially since it wasn't an issue before... Anyone else dinking with the engine?Scott
Originally posted by TownsendsFJR1300 View PostYou may want to buy the entire kit to 100% performance. Its not much more.
I got everything buttoned up after the water pump kit install and destroyed the new impeller immediately thereafter. I used a pair of muffs that were not mine and they did not provide enough water to the impeller. I should have known better. I'm now waiting on a second kit with a new housing since that got jacked up too. I figured out that if you don't have the gear shift shaft in neutral when you install the lower unit, you end up with no reverse. Lol
Â
