have a pair of 2000 250 hp ox 66 engines on a 30' pursuit.Getting about.7 mpg at cruise seems very low and less at slower speeds.Good fuel,clean filters and vst screens.Should be much better from what i've read.Any Ideas?Heard 02 sensor could cause this.Has correct props according to books.Passed survey in spring.
ox 66 250 hp high fuel consumption
in the water world we don't use MPG.
to many variables.
we do use GPH or LPH.
that motor at or near wot can burn 25-28 gallons per hour.
at cruise you will blow about 10-12 GPH.
the O2 sensor is a fuel trim device wont affect much.
the regulator has a screen, if the screen clogs it spikes rail pressure.
will burn a lot of fuel and run rich.
